[GRASSLIST:5761] v.extract incorrect output
I'm running grass5.0 on RH8 linux.
I'm extracting one county border from a vector of all counties for the state of New Jersey, USA.
I do this:
v.extract -n type=area list=ESS input=stco_CO output=essex.border new=1
but wind up with the polygon for MOR (see below cats).
here's part of the dig_cats file.
# 23 categories
Vector map: stco_CO
0.00 0.00 0.00 0.00
1:SUS
2:PAS
3:BER
4:WAR
5:MOR
6:ESS
7:HUD
When I do:
v.extract type=area list=6 input=stco_CO output=essex.border new=1
I get both ESS and SUS polygons combined in one vector. (As if I did list=1,6)
The vector map stco_CO was created with:
v.in.shape -o in=stco.shp out=stco_CO label=CO scale=24000
v.support map=stco_CO option=build
Is it me, or does v.extract have problems?
Phil
On Monday 10 March 2003 03:48 am, Philipp Molzer wrote:
I do this:
# 23 categories
Vector map: stco_CO
0.00 0.00 0.00 0.00
1:SUS
2:PAS
3:BER
4:WAR
5:MOR
6:ESS
7:HUD
There is a bug in v.extract for '-n' option. It uses index instead of
category!!! For example for dig_cats
1:A
10:B
and list=A,B you get cat list 0,1. So your output is 'correct'
( 5(MOR) instead of 6(ESS) ) :slight_smile:
I disabled '-n' option 3 months ago (after 5.0.0 release).
This is the most interesting bug I have ever found in GRASS,
output is obviously wrong and the module is there for years
(1.0 10/01/89 mentioned in code).
Conclusion: It is not so important how the program works
as we can see on other popular SW.
Try to make the project with MOR instead of ESS and I think
that there is a good chance that nobody other will notice that.
When I do:
list=1,6)
This seems to be another bug. Did you check if cats are realy correct
in the input (d.what.vect)? Then we can narrow it to either v.extract or
v.in.shape.
Radim
