I am attempting to import some ASTER images with Michael Barton's r.in.aster and
I'm getting the error message that gdalwarp is missing (error message pasted
below). I am using GRASS6.0 under Cygwin on WinXP downloaded from the binary
posted on Huidae Cho's website. Is it possible that gdalwarp is missing or
perhaps is in in the wrong place? I have searched for it and can't find it
under any of the normal directories (or any directory).
Is there somewhere that I can download the gdalwarp utility to make this functional?
Teague
Teague O'Mara
Department of Anthropology
Arizona State University
Box 872402
Tempe, AZ 85287-2402
480.965.6213
r.in.aster and I'm getting the error message that gdalwarp is missing
(error message pasted below). I am using GRASS6.0 under Cygwin on
WinXP downloaded from the binary posted on Huidae Cho's website. Is
it possible that gdalwarp is missing or perhaps is in in the wrong
place? I have searched for it and can't find it under any of the
this functional?
Teague is using Huidae Cho's Cygwin binaries. It seems like libgdal is
available from the site, but not the other gdal (or ogr?) utilities. Is
there a chance that the entire gdal utility set could be made available in
binary form for windows/cygwin users? I assume that Huidae has been
successful in compiling it for that platform.
Michael
____________________
C. Michael Barton, Professor of Anthropology
PO Box 872402
USA
Date: Tue, 15 Feb 2005 17:42:02 +1300
To: Teague O'Mara <Teague.Omara@asu.edu>
Cc: <grasslist@baylor.edu>, <wingrass@grass.itc.it>, <Alex.Miller@asu.edu>
Subject: [GRASSLIST:5772] Re: gdalwarp and gdal libraries
this functional?
Is there a chance that the entire gdal utility set could be made
available in binary form for windows/cygwin users? I assume that
Huidae has been successful in compiling it for that platform.
perhaps add to the script a test for gdalwarp?
See the scritps/r.out.gdal test for gdal_translate:
#check gdal_translate exists
if [ -z "`which gdal_translate`" ] ; then
echo "ERROR: Required program gdal_translate is missing"
echo " Full GDAL binaries with GDAL/GRASS support are needed to use r.out.gdal."
exit 1
fi
You're right. I forgot to include utilities. I'll take care of it with the
next binary distribution.
Huidae Cho
Michael
PO Box 872402
USA
> From: Hamish <hamish_nospam@yahoo.com>
>> this functional?
> gdalwarp comes as part of the GDAL package.
> http://gdal.org
> Hamish
Did you know...
If you play a Windows 2000 CD backwards, you hear satanic messages,
but what's worse is when you play it forward....
...it installs Windows 2000
