[GRASSLIST:5769] problems with shapefiles created with v.out.ogr
Not sure what is causing this... but when i import a shape file into GRASS
with v.in.ogr, make changes, and then export the resulting file with
v.out.ogr, there are some geometry problems - specifically when converting
the output shapefile into GMT-style x,y data.
The results look like the polygons are note closed (properly?)
importing the original shape file with v.in.ogr -c only made things worse --
incorrect attributes where assigned to polygons.
It could be that I have a slightly funky shapefile, but this problem makes me
very wary of working with shapefile within GRASS - especially when i need to
export the data for some other application.
Could this be related to a badly formed shapefile, or is this part of a larger
problem with importing/exporting shapefiles?
Any thoughts would be appreciated.
thanks in advance,
Dylan Beaudette
Soils and Biogeochemistry Graduate Group
University of California at Davis
530.754.7341
