Thanks, Moritz. I had no problems to create the test.dbf with touch
test.dbf and the permissions are as follow: the /.tmp/Jan1 directory
drwxr-xr-x+ and the test.dbf -rw-rw-rw- and I am the owner of the files...
> -----Ursprüngliche Nachricht-----
> Von: owner-GRASSLIST@baylor.edu [mailto:owner-GRASSLIST@baylor.edu] Im
> Auftrag von Moritz Lennert
> Gesendet: Dienstag, 15. Februar 2005 14:55
> An: Jan Bartholdy
> Cc: English Grasslist
> Betreff: [GRASSLIST:5781] Re: v.in.ascii, grass6.0 binary version for
> cygwin
> On Tue, February 15, 2005 14:46, Jan Bartholdy said:
> > Dear All,
> > I have imported an ASCII table (tab's as field separators) into grass
> > without problems using v.in.ascii input= output= without any arguments
> > (using arguments like columns="...", the problem is the same).
> > All coordinates are imported and the correct number of colums and
their
> type
> > was recognized. After that, an error message occur: mv: cannot move
> > /home../../.tmp/Jan1/5164.dbf to /home/.../topo/dbf/species_1.dbf:
> > permission denied.
> > After that, the module building topology etc.
> > The 5164.dbf file remains in the .temp/Jan1 folder.
> > With d.vect, I can display the points, but the labels are not present.
> > Db.colums gives an error : DBMI-DBF driver error: Table species_1
> does'nt
> > exist
> This looks like you do not have permission to write to the second
> directory.
> Try to go to the directory and do a "touch test.dbf" or could you do an
ls
> -ld
> on the second directory (and its parents) to show the permission
settings
> Moritz____________
Virus checked by G DATA AntiVirusKit
Version: AVK 15.0.2975 from 09.02.2005
____________
