I have used r.in.gdal to import a rgb tif (it is a scanned map). I'd
like to display it as it looks when I view it with gimp. r.in.gdal
imported the tif as test.1, test.2, and test.3 (I assume for the 3 color
bands). After reading though some man pages, it looks like d.rgb is what
I should use to superimpose all 3 bands (hopefully getting something
that looks "colorwise", like the original tif).
However, no matter which order I "superimpose" the color bands with
d.rgb, I can not get anything to look like the original. I am using the
wrong function here, or perhaps just applying it incorrectly?
Kirk
Kirk R. Wythers Department of Forest Resources
Tel: 612.625.2261 University of Minnesota
Fax: 612.625.521 1530 Cleveland Ave. N
Email: kwythers@umn.edu Saint Paul, MN 55108 USA
On Fri, 2003-05-16 at 15:21, John Preston wrote:
You need to set the colors to grey scale for the three maps test.1,
test.2 and test3.
ie. r.colors map=test.1 golor=gray
etc
then d.rgb will work.
That did it. Thanks
> Kirk
> test.2 and test3.
> etc
Actually, you should use color=rules, e.g.
GRASS:~ > r.colors map=test.1 color=rules
Enter rules, "end" when done, "help" if you need it.
Data range is 0 to 255
> 0 black
> 255 white
> end
Color table for [test.1] set to rules
This will ensure that 0 is black and 255 is white.
Using color=gray will map the lowest existing category to black and
the highest existing category to white; if the map doesn't use the
entire 0-255 range, you will get the wrong result.
Also, you can read the rules from a file with e.g.
r.colors map=test.1 color=rules < gray.rules
where gray.rules contains:
0 black
255 white
end
Glynn Clements writes:
Why is this left up to users to set correctly? Why doesn't importing
an image do this automatically?
--My blog is at angry-economist.russnelson.com | "I have officially heard
Crynwr sells support for free software | PGPok | every excuse for being
521 Pleasant Valley Rd. | +1 315 268 1925 voice | assigned a single room at
Potsdam, NY 13676-3213 | +1 315 268 9201 FAX | FGC." --Liz Perch
Because r.in.gdal doesn't write a colour table unless the file itself
has a colour table (bear in mind that r.in.gdal isn't just for
images). Or, rather, it didn't in 5.0.2 and earlier; this has recently
been fixed in the CVS HEAD.
Also, GDAL itself goes a bit too far in its abstraction; the caller
just gets a grid of integers, with no way of knowing what the "white"
value should be. The CVS HEAD version guesses, and uses 0-255 for
8-bit unsigned data and 0-65535 for unsigned 16-bit data (i.e. if you
import 4-bit or 12-bit data, you will get a very dark image).
BTW, this was discussed in mid-March on the development list, in the
thread entitled "r.in.gdal updates?".
Good! You should set defaults so that most people don't need to
change them.
bands).
BTW: I have updated r.in.gdal to write in this case
test.blue, test.green, test.red
and to apply a grey scale color table.
The new version should come with 5.0.3 (or get the source code from CVS).
Yes.
You have to assign a grey color table first:
r.colors test.1 col=grey
r.colors test.2 col=grey
r.colors test.3 col=grey
d.rgb ...
Hope this helps,
Markus Neteler
> > test.2 and test3.
> > etc
> 0 black
> 255 white
> end
Right - sorry for the r.colors mistake in my previous mail.
The updated r.in.gdal applies above suggested fixed color table.
Markus Neteler
