[GRASSLIST:5839] vector point cropping
I have a points-vector & I want to cut out all points that fall within a
polygon.
In GRASS 5.4 you could use s.mask to do this.
In GRASS 5.7, v.select looks like it would work if there was a
"operator=not" option or if v.overlay worked for points.
Any ideas?
Hamish
Dear All,
GRASS60, I tried cropping
area vector with points but failed.
in GRASS5.7 it was OK.
Pl act and solve this.
Ravi
--- Hamish <hamish_nospam@yahoo.com> wrote:
polygon.
there was a
points.
Any ideas?
Hamish
__________________________________
Do you Yahoo!?
All your favorites on one personal page – Try My Yahoo!
http://my.yahoo.com
more details are needed. Exact commands? Exact output? Can you reproduce
it with the spearfish57 data set?
> points that fall within a polygon.
> there was a "operator=not" option [for v.select] or if v.overlay
> worked for points.
> Any ideas?
> Hamish
Solution:
[v.hull +] v.in.region + 'v.overlay operator=not' to make a negative
mask of a the polygon, and then 'v.select op=overlap' to only keep the
points in the negative-mask.
Hamish
Thanks for the solution.
I will try..
But in GRASS60
Iam unable to
cut a area vector with a points vector
to result in only vectors that contain points.
I find that the result area has vector even not
including any points.
IS THERE A SNAP LIMIT OR WHAT??
Ravi
if
or if v.overlay
> > worked for points.
> > Any ideas?
> > Hamish
Solution:
make a negative
Hamish
Do you Yahoo!?
Yahoo! Mail - Find what you need with new enhanced search.
http://info.mail.yahoo.com/mail_250
