Dear users,
I'd like to import a shapefile into GRASS6.0 and use v.in.ogr .
The module doesn't create an attribute table:
v.in.ogr dsn=. output=le_ausschr_hg_biotopkartierung_biotope
layer=le_ausschr_hg_biotopkartierung_biotope
PROJ_INFO file not found for location landschaftselemente
PROJ_UNITS file not found for location landschaftselemente
Projection of input dataset and current location appear to match.
Proceeding with import...
Layer: le_ausschr_hg_biotopkartierung_biotope
DBMI-DBF driver error:
SQL parser error in statement:
create table le_ausschr_hg_biotopkartierung_biotope (cat integer, ID
integer, AREA double precision, PERIMETER double precision, BIOTOPE_S_
integer, BIOTOPE_S2 integer, EB integer, ST integer, SM integer, ENUM
varchar ( 16 ), NAM varchar ( 25 ), FLA double precision, SA double
precision, W double precision, WHERE integer, KARTE integer, NUMMER
integer, RECNR integer, FLAECHE double precision, XKOOR double
precision, YKOOR double precision, BIOTOP_NR integer)
Error in db_execute_immediate()
ERROR: Cannot create table: create table
le_ausschr_hg_biotopkartierung_biotope (cat integer, ID integer,
ENUM varchar ( 16 ), NAM varchar ( 25 ), FLA double precision, SA
double precision, W double precision, WHERE integer, KARTE
integer,
NUMMER integer, RECNR integer, FLAECHE double precision, XKOOR
double precision, YKOOR double precision, BIOTOP_NR integer)
I already moved the ID column to the first position, nothing changes.
So what could I do else?
Thanx Larissa
