Greetings all,
Whenever I try to change any of the sliders in NVIZ, I an eeror. For example, when I change the zexag slider I get the message:
can't read "Priv(.top2.panelarea.panels.main.midf.zexag.scale,relief)": no such element in array
while executing
"$w configure -sliderrelief $Priv($w,relief)"
(procedure "tk::ScaleEndDrag" line 4)
invoked from within
"tk::ScaleEndDrag .top2.panelarea.panels.main.midf.zexag.scale"
(command bound to event)
I'm using grass6.0.beta2 (same thing happened with beta1) under SuSE 9.0. Everything seemed to compile correctly. Any suggestions would be greatly appreciated.
Andy Bernat
