[GRASSLIST:5874] ERROR: MAPSET PERMANENT in make
Why when I'm running make (grass5.6beta2) i get the following error?
ERROR: MAPSET PERMANENT - permission denied
But I'm only compiling the source code and no GISDB still defined.......
What I'm missing???
Thanks.
Maxi
_____________________________________________________
Ing. Massimiliano Cannata
SUPSI - Istituto Scienze della Terra
C.P. 72 - CH-6952 Canobbio (Ticino, Switzerland)
Tel +41 (0)91 935 12 25 - Fax +41 (0)91 935 12 09
mailto:massimiliano.cannata@supsi.ch
http://www.ist.supsi.ch
defined....... What I'm missing???
When you compile it makes a fake mapset to generate the help pages.
Check you have full write permissions and disk space in the directory
you are compiling in as well as /tmp/ and $TMPDIR (if it exists).
Hamish
