Yesterday I installed ImageMagick via Fink. Today I started up GRASS and when I started a monitor, x0, I got this message:
Warning: Color name "DarkSlateBlue " is not defined
Warning: Cannot convert string "true xterm*saveLines: 10000 " to type Boolean
while executing
"exec xterm -geometry 40x5 -e d.mon start=$monitor"
(procedure "start_monitor" line 17)
invoked from within
"start_monitor x0"
invoked from within
"$menu post $x $y"
(procedure "PostOverPoint" line 27)
invoked from within
"PostOverPoint $menu $x $y"
("below" arm line 4)
invoked from within
"switch [$w cget -direction] {
above {
set x [winfo rootx $w]
set y [expr {[winfo rooty $w] - [winfo reqheight $menu]}]
(procedure "tk::MbPost" line 37)
invoked from within
"tk::MbPost $tk::Priv(inMenubutton) 108 110"
invoked from within
"if {$tk::Priv(inMenubutton) ne ""} {
(command bound to event)
I know Fink installed some X11 stuff and am assuming the 4 warnings are related to that but have no idea how to correct this. The other possibility is that Alsoft's PlusOptimizer has caused the problem. I installed and ran it Monday and immediately had problems closing apps--I had to kill them. I've since run fsck and, for now, that problem has not reappeared. If you've not already guessed, I'm running Grass 5.0 on OS X (10.2.4) using Apple's X11 betta 3.
ec
