[GRASSLIST:5879] problem of v.out.shape
Greetings,
I got "segmentation fault" when I used "v.out.proj"
to convert some vectors which was obtained by "r.poly"
from some raster". What I do were following:
r.poly
v.support
then
v.out.proj map= type=area
Segmentation Fault
But if I used type of line, the conversion was done.
i.e. v.out.proj map= type=line.
Any idea or suggestion? Thank you.
Xueming
Greetings,
r.poly
v.support
then
Segmentation Fault
Xueming
On Wed, Mar 26, 2003 at 03:19:17PM -0600, Xueming Wu wrote:
Greetings,
r.poly
v.support
then
Segmentation Fault
From the change logs for v.out.shape...
2002-10-03 22:34 eric
        * extract.c: Fix memory corruption bug with areas w/ islands.
I think the version in 5.0.1 has the fixed version...
echo ">gra.fcw@2ztr< eryyvZ .T pveR" | rot13 | reverse
