I wanted to search the grass M.L. archives because I had problems importing dxf with v.in.ogr (200 Mb of laser scanner 3D points, some joker exported them in dxf instead of ascii and I wanted to use grass to import them and expor in 3d ascii points) using grass60 and I heard someone already solved the problem thanks to the mailing list. The problem is that searching the list with htdig I do not get any results for any combination of search words, even a single word! Is there any problems with the htdig search engine or am I missing something??
Thanks guys,
Francesco Pirotti
CIRGEO
Interdepartment Research Center of Photogrammetry,
Remote Sensing, Cartography and GIS
University of Padua
Viale dell'Università 16 - Legnaro - PD
www.cirgeo.unipd.it
phone +39.328.2126861
phone +39.049.827.2522/2688
fax. +39.049.8272686
You'll probably want to use v.in.dwg [*] for this. v.in.dxf in GRASS 5.4
might work too.
[*] non-Free libary req., must build yourself & can't redistribute.
something??
