[GRASSLIST:5891] GRASS on Cygwin
Hi GRASSusers,
I'm having a problem (after many others) in compiling GRASS5.0.1 under
Cigwin. I did successfully configure,make and make install, but
when I run grass5 I have this message:
/usr/local/bin/grass5: line 106 : [: too many arguments
ERROR: usage: /usr/local/grass5/etc/lock file pid
Clerici is currently running GRASS. Concurrent use is not allowed.
Where I failed?
Many thanks
Aldo Clerici
Parma University
Where I failed?
GRASS can't handle spaces in directory names, but your home directory
contains a space (presumably "/home/Aldo Clerici").
Try changing your home directory in the /etc/passwd file; OTOH, you
might also need to explicitly set HOME in your ~/.bashrc file, i.e.
  HOME=/home/aldo
  export HOME
The latest CVS version includes some changes to handle spaces in
filenames (at least the startup code should be fixed; individual
modules may still have problems, though).
