[GRASSLIST:5912] v.convert problem - OSX, 6.0cvs
Dear Grass Users,
I was bringing some old vector maps into GRASS 6.0, using Lorenzo Moretti's excellent new version for OSX. I imported once without realizing that the database connection was set to odbc (left over from an unsuccessful attempt to connect to a Filemaker database using ODBC). The process failed when trying to attach categories to the data:
DBMI-ODBC driver error: SQLConnect():
[unixODBC][Driver Manager]Invalid string or buffer length (0)
GRASS_INFO_ERROR(827,29): Cannot open database /Users/nick/Grass/sardis/PERMANENT/dbf/
I then set the database connection to dbf (db.connect), and imported the file again using a different name. This time it apparently imported all right, but the new vector files are not recognized -?- as new vector files; when I try to set the region to the new vector file I get an error
g.region vect=con10_beta1
Cannot open old vector con10_beta1@PERMANENT on level 2
Trying to display the new vector causes an error:
child process exited abnormally
     while executing
"exec -- d.vect map=con10_beta1 color=0:0:0 lcolor=0:0:0 fcolor=170:170:170 display=shape type=point,line,boundary,centroid,area icon=basic/x size=5 la..."
blah blah...
Nor can I remove the new converted map:
g.remove vect=con10_beta1
Cannot open old vector con10_beta1@PERMANENT on level 1
REMOVE [con10_beta1]
I've tried this in both beta 1 and beta 2, with no success. Any help out there?
BTW I would also like to know if anyone has gotten ODBC to work with GRASS under OS X.
Nick Cahill
