I am working with Debian/unstable's GRASS 6.0.0beta2. I've looked at
the tutuorials, but they don't give much guidance on how to display
USGS DEMs, in particular since the DEM files themselves seem to be
somewhat opaque. I get lots of mismatches, particularly since I don't
know what I am doing. For example, I try:
I've imported the DEM, e.g.:
$ r.in.gdal input=A145121.DEM output=A145121
which seemed to go okay. Then:
$ nviz elevation=A145121
Error: Raster A145121@russell is outside of current region
Load Failed.
Guidance appreciated.
Russell Senior ``I have nine fingers; you have ten.''
seniorr@aracnet.com
Load Failed.
Zoom to the geographic extents of your map before trying to display them:
g.region rast=A145121
also, it might be better to start with a simpler 2D view before trying NVIZ.
There is a small gap between the two rasters. How can I stitch them
together? Also, is there an easy way to draw on a long/lat grid so
that I can orient myself more easily?
Thanks!
seniorr@aracnet.com
Thanks!
seniorr@aracnet.com
