[GRASSLIST:5925] Grid transformations
Greetings grassers,
I would be very grateful if anyone could let me know how to do regridding
with GRASS5. Specifically, I want to take the EMEP emissions maps of
sulphur, nitrogen, VOC and carbon monoxide (http://webdab.emep.int/
<http://webdab.emep.int/&gt; ), which are on a polar-stereographic projection,
and re-cast them on a Lambert Conformal grid in various grid square sizes
from 4 to 108km. Is this possible with Grass? What do I need to do? Any help
would be much appreciated.
Thank you.
Ray D Wright
The information contained in this email is intended only for the
use of the intended recipient at the email address to which it
has been addressed. If the reader of this message is not an
intended recipient, you are hereby notified that you have received
this document in error and that any review, dissemination or
copying of the message or associated attachments is strictly
prohibited.
If you have received this email in error, please contact the sender
by return email or call 01793 877777 and ask for the sender and
then delete it immediately from your system.
Please note that neither Innogy nor the sender accepts any
responsibility for viruses and it is your responsibility to scan
attachments (if any).
Create two locations; one whose projection matches the source data,
and one with the projection you wish to use. Start GRASS using the
first location, and import the data. Exit GRASS, restart it using the
second location, then use r.proj to reproject the data.
