H_S_Rai
1
I tried to install GRASS on debian (Testing), on following grass
website, which points to Debian GIS, I put required lines in
apt/sources.list
deb http://pkg-grass.alioth.debian.org/debian-gis testing main non-free
contrib
deb-src http://pkg-grass.alioth.debian.org/debian-gis testing
main non-free contrib
deb file:/home/software/debian sarge packages
On "apt-get update", it says "file Packages" not found. How I can use
apt-get to install Grass6.0 on Debian.
If I try source, it says "zlib" header file not found. And I could not
find package to be installed from 15 CDs of Debian Testing.
Please give me pointer to enable me to install it on Debian. GRASS5.2 is
there on CDs, which I could install easily.
Thanks in advance,
Hardeep Singh Rai
H.S.Rai
Alternate Email: hsrai@gmx.net
You have to change "testing" to "unstable"... doing that apt-get will
work, and install GRASS 6.0 beta 2, ok?
Christian S. Ferreira
Federal University of Rio Grande
Rio Grande - RS - Brazil
apt/sources.list
contrib
Why do you need this last line ? The first two are enough to get the debian
packages.
See http://pkg-grass.alioth.debian.org/cgi-bin/wiki.pl?DebianGisRepository for
exact instructions, including for pinning to make sure that you get the
packages from DebianGIS and not from the main Debian repository.
This is due to the last line...
Moritz
apt/sources.list
The easiest thing to do is to use the grass packages coming from Sid !
They are the same as the one from pkg-grass.alioth.debian.org.
Using AptPreferences you will stay on sarge but may use grass packages
from Sid
Didrik
Hello Hardeep,
On Mon, 28 Feb 2005 04:05:01 -0800 "Hardeep Singh Rai" <hardeep@eml.cc>
apt/sources.list
free contrib
I think there are no testing-packages on alioth.
you should user unstable instead of testing in /etc/apt/source.list
This should allow apt-get update to find the correct file.
is there on CDs, which I could install easily.
recently I heard that GRASS filtered into sarge officially, so an
apt-get install grass should do (untested).
Stephan
Stephan Holl
Check headers for GnuPG Key!
http://www.gdf-hannover.de
Yes, but this way you can't get the newest stuff (qgis-grass-plugin,
libgdal1-grass).
All the best.
pc
Stephan
Paolo Cavallini
cavallini@faunalia.it www.faunalia.it www.faunalia.com
Piazza Garibaldi 5 - 56025 Pontedera (PI), Italy Tel: (+39)348-3801953
