[GRASSLIST:5939] Label files from .dxf
Hi folks,
New question. Apparently, when I imported the .dxf file with v.in.dxf the contour labels did not import into the vector files. I also ran v.in.dxf3d. That did seem to help. The .dxf file does have data labels. Is there a way I can get those labels to apply to the map with out going in and doing it manually? This map has a lot of contours.
Kurt
