Hello all,
Does anyone know how I can, in a Linux box, convert MicroStatio *.dgn files
into dxf or shape, or something that GRASS can read?
tks
Carlos Henrique Grohmann de Carvalho - Guano
Geologist - MSc Student at IGc-USP - Brazil
Linux User #89721 PGP key: www.keyserver.net
Carlos Henrique Grohmann de Carvalho wrote:
Hello all,
Does anyone know how I can, in a Linux box, convert MicroStatio *.dgn files into dxf or shape, or something that GRASS can read?
Carlos,
The "ogr2ogr" application (part of GDAL/OGR) provides conversion of
DGN files to Shapefiles. In GRASS 5.1, DGN files should be useable directly.
http://gdal.velocet.ca/projects/opengis/
Note that DGN files generally contain a mixture of geometry types, while
shapefiles may only have one type of geometry so you will need to do some
fooling around to translate the DGN file into a "point", "line", and "polygon"
file to capture all features in a complex dataset.
Good luck,
I set the clouds in motion - turn up | Frank Warmerdam, warmerdam@pobox.com
light and sound - activate the windows | http://pobox.com/~warmerdam
and watch the world go round - Rush | Geospatial Programmer for Rent
