[GRASSLIST:5967] HELP! v.in.shp and database
The manual says there is a command v.in.shape.pg that build the entire database file from the esri shape file. does anyone know why when I type this it says command not found?
Also - if this command does not exists - how do I go about creating the attribute database for the grass vector file once I have imported it with v.in.shape.
Is there a GRASS database tutorial?
THANKS
Schuyler Fishman
Schuylerfish@earthlink.net
www.mindlikesky.com
Try "pg.in.dbf" instead of "v.in.shape.pg"
----- Original Message -----
From: "Schuyler Fishman" <schuylerfish@earthlink.net>
To: <grassLIST@baylor.edu>
Sent: Saturday, April 05, 2003 11:22 AM
Subject: [GRASSLIST:5967] HELP! v.in.shp and database
with v.in.shape.
THANKS
Schuyler Fishman
www.mindlikesky.com
