Hello;
I compiled grass5 from the sources into my machine. But I want to install
the binary ones that I obtained in another machine. Without having to
recompile.
I can do it with make or with stable version of grass install script?
Or always I must compile in every machine that I want to install the last
version of grass?
Miguel
recompile.
version of grass?
You should be able to copy the binary installation between similar
machines. You need the installation directory (e.g. /usr/local/grass5),
plus the grass5 script (e.g. /usr/local/bin/grass5).
The simplest way is to create a tar file, e.g.:
tar cf ~/grass.tar /usr/local/grass5 /usr/local/bin/grass5
then copy it to the destination machine and extract it, e.g.:
tar cCf / ~/grass.tar
