In my opinion, the length of 50 characters are too restrictive,
considering most configurations of file system in modern machines.
No possibility to relieve the restriction?
Daehyok Shin (Peter)
-----Original Message-----
From: owner-GRASSLIST@baylor.edu [mailto:owner-GRASSLIST@baylor.edu]On
Behalf Of Glynn Clements
Sent: Friday, April 11, 2003 AM 11:21
To: Shin, Daehyok
Cc: GRASSLIST@baylor.edu
Subject: [GRASSLIST:6022] Re: [Q] Long path for DATABASE
Shin, Daehyok wrote:
Maybe a trivial question, but I can't find the answer
from the web site.
How can I put in a very long path to DATABASE
in the first setup window of GRASS?
You can't; the interactive startup imposes a 50-character limit upon
the database directory.
However, you can avoid that limit by using the non-interactive
startup, i.e.
grass5 /path/to/database/location/mapset
