Hi grassusers
Could anyone tell me why my grass6.1 doesnt have gdal support.
i think i did everything correct,(maybe not)
1)
I installed gdal (from source) --without-grass,
2)
installed grass61 (from source) and everything worked fine with the exception of r.in.gdal and r.out.gdal
so i installed gdal-grass-1.3.1
./configure --with-gdal=/usr/local/bin/gdal-config
--with-grass=/usr/local/grass-6.1.cvs
configuration and installation of gdal-grass looked ok
but my grass61 still dont have gdal support and i dont know why.
my system is opensuse10
thankful for any help
regards
Maciej Tomaszczyk
H_B
2
1)
2)
exception of r.in.gdal and r.out.gdal so i installed gdal-grass-1.3.1
r.in.gdal should work. what was the error? did you add /usr/local/lib to
/etc/ld.so.conf and run ldconfig as root?
for r.out.gdal make sure that if you do "gdalinfo --formats" GRASS is
listed as a supported type.
may be better to use the GRASS plugin rather than recompile GDAL after
installing grass:
http://www.gdal.org/dl/gdal-grass-1.3.1.2.tar.gz
path name of the plugin library was significant IIRC, search the archives.
Hamish
Not an expert advise, but why not try to install the latest grass cvs
with the shell script, and then install all the rpms from rpmfind.net etc.
i work this way and no problems so far…
Ravi Kumar
Maciej Tomaszczyk mtom@pgi.gov.pl wrote:
Yahoo! Messenger with Voice. Make PC-to-Phone Calls to the US (and 30+ countries) for 2¢/min or less.
hi
i installed the latest version of grass61 one more time and now everything works fine:)
thanks for help
Maciej Tomaszczyk
Polish Geological Institute
Geological Mapping Department
-----Wiadomość oryginalna-----
Od: RAVI KUMAR [mailto:ravivundavalli@yahoo.com]
Wysłano: Pt 2006-04-07 09:18
Do: Maciej Tomaszczyk
DW: grasslist@baylor.edu
Temat: Re: [GRASSLIST:605] gdal-grass in grass61, how to?
i work this way and no problems so far..
Ravi Kumar
Maciej Tomaszczyk <mtom@pgi.gov.pl> wrote:
Hi grassusers
1)
2)
regards
Maciej Tomaszczyk
Yahoo! Messenger with Voice. Make PC-to-Phone Calls to the US (and 30+ countries) for 2c/min or less.
