[GRASSLIST:607]
to all.
I received this messages from our virus scanner:
thanks to all
marino
This e-mail is generated by the mailserver.dipteris.unige.it mail server to warn you that the e-mail
sent by owner-grasslist@baylor.edu to zucco@dipteris.unige.it is infected with virus: Win32/Sobig.E@mm.
Please contact your system administrator for further information.
If you are the sender:
The scanned e-mail has your address in the <From> header field. Either your
computer is infected or someone's computer having your e-mail address in
the address book has been infected.
(Please note that some viruses are sending e-mails directly from your computer.
Our advise is to check your computer using an up-to-date antivirus product).
If you are the receiver:
Please contact the sender: very probably he/she doesn't know he/she has a computer virus.
Actions taken for the infected files:
The infected file was saved to quarantine with name: 1057305702-758462.msg.
The file (part0003:your_details.zip)->details.pif attached to mail (with subject:[GRASSLIST:605] Re: Application) sent by owner-grasslist@baylor.edu to zucco@dipteris.unige.it
Cannot clean this file.
Cannot delete this file (most probably it's in an archive).
The mail was not delivered because it contained dangerous code.
this is a copy of the e-mail header:
Received: from ccis01.baylor.edu ([129.62.1.18] verified)
   by dipteris.unige.it (CommuniGate Pro SMTP 4.0.5)
   with ESMTP id 758462 for zucco@dipteris.unige.it; Fri, 04 Jul 2003 10:01:40 +0200
Received: from localhost (ccis01.baylor.edu [129.62.1.18])
  by ccis01.baylor.edu (8.9.3p2/8.9.1) with SMTP id DAA1368089;
  Fri, 4 Jul 2003 03:01:01 -0500 (CDT)
Received: from FS-EXCHANGE1.baylor.edu (flopsy.baylor.edu [129.62.3.249])
  by ccis01.baylor.edu (8.9.3p2/8.9.1) with ESMTP id CAA1368050
  for <GRASSLIST@listproc.baylor.edu>; Fri, 4 Jul 2003 02:58:25 -0500 (CDT)
Received: from waylon.baylor.edu ([129.62.3.228]) by FS-EXCHANGE1.baylor.edu with Microsoft SMTPSVC(5.0.2195.4561);
Received: from willie.baylor.edu ([129.62.3.227]) by waylon.baylor.edu with Microsoft SMTPSVC(5.0.2195.4561);
Received: (from WXD [61.149.92.181])
  by willie.baylor.edu (SAVSMTP 3.1.1.32) with SMTP id M2003070402580631195
  for <GRASSLIST@baylor.edu>; Fri, 04 Jul 2003 02:58:09 -0500
RAV AntiVirus for Linux i386 version: 8.4.1 (snapshot-20021217)
Scan engine 8.11 for i386.
Last update: Thu, 03 Jul 2003 17:16:18 +02
Scanning for 79754 malwares (viruses, trojans and worms).
Marino Vetuschi Zuccolini
PhD / Geochemist
PESTO Group
Permanent Earth Science Technical Observatory Group
http://ugo.dipteris.unige.it/pesto
Visit our BAXEICO computing cluster homepage
http://qed.dipteris.unige.it/ganglia
