[GRASSLIST:6086] Re: 5.0.2 problem
well than I misunderstood the release notes http://grass.itc.it/grass5/source/NEWS.html
I thought that r.series and ! r.mapcalc3 (i.e new: r.mapcalc): errors fixed (Glynn Clements) are normal commands and are now included in the new GRASS version. But they are only in the source code, right?
well then I will give the source code a go.
cheers Martin
P.S.: only for interest: how do I install r.series with the binary?
> r.series isn't built by default (and so won't be in any of the binary
> distributions).
> There isn't an "r.mapcalc3" program; the new version of r.mapcalc is
> called "r.mapcalc" (the source code is in src/raster/r.mapcalc3; the
> old r.mapcalc is still in the source package, but isn't built).
I guess you are refering to r3.mapcalc? The volume tools?
They *may* show up in 5.0.3 as they are rather stable now.
Markus Neteler
Martin Wegmann
Department of Animal Ecology and Tropical Biology
Zoology III, Biocenter
Am Hubland
D-97074 Würzburg
Germany
E-Mail:
wegmann@biozentrum.uni-wuerzburg.de
m.wegmann@web.de
______________________________________________________________________________
UNICEF bittet um Spenden fur die Kinder im Irak! Hier online an
UNICEF spenden: https://spenden.web.de/unicef/special/?mc=021101
r.series is only available if you compile GRASS from the source code.
It isn't built as a result of running "make" (which is why it isn't in
the binary packages); you have to compile it separately (or modify
src/CMD/lists/GRASS before running "make").
The new r.mapcalc *is* in the binary packages (from at least -pre4
onwards); the program itself is called r.mapcalc, although the source
code is in src/raster/r.mapcalc3. The *old* r.mapcalc isn't in the
binary packages, but its source code is still in the source packages
(and CVS), in src/raster/r.mapcalc.
I installed grass 5.0.2 source code sucessfully (well no error messages at the
end :wink: ) and read the part "compiling modules not compiled by default" in the
INSTALL GRASS text, to install r.series.
how do I compile it seperately? in the INSTALL textit is described that you
have t type gmake5 in the modules's directory, but in which directory shall
the module directory be - the one in /usr/local/... or
the one in my home directory from where i installed GRASS? - either in the
module directory under / (only one called module:
/usr/local/grass5/tcltkgrass/module) nor under ~/ could I find r.series.
cheers Martin and happy Easter
It is referring to the directory which contains the module's source
code.
GRASS version.
... I have clarified the NEWS.html.
"+ r.mapcalc (the new r.mapcalc): errors fixed (Glynn Clements)
+ r.series: added for time series analysis, not in binary version (Glynn Clements)
