[GRASSLIST:6103] Problem with s.delaunay
Hello.
I am using GRASS 5.0.1 and I am trying to do a TIN model from a sites file with the ‘s.delaunay’ command.
If the sites file is a 2D point file the process is fine; but if the sites file is a 3D point file, the process cannot be done and appears a ‘Memory fault’ error message (as shown below).
GRASS-GRID > s.delaunay -l sites=pru.punz vect=pru.tinz
Storing triangle number as category label
Writing vector cats
Memory fault
Why do this error happen? Is there any problem with ‘s.delaunay’ and 3D files? And if this is so, how could do a TIN model from a 3D point file (with x,y,z coordinates) and without losing the ‘Z’ coordinate?
I would be glad if anyone could help me.
Regards.
Juan Mari Celihueta.
