Hello
I encounter a problem using NVIZ in grass5 and rh 9.
I tried to fix the problem by soft link of libtk.so.0 to
libtk.so. But the problem is not solved.
what do you recommend me ?
Here is the error message:
/usr/local/grass5/etc/nviz2.2/NVWISH2.2: error while loading shared libraries: libtk.so.0: cannot open shared object file: No such file or directory
child process exited abnormally
while executing
"exec /usr/local/grass5/etc/nviz2.2/NVWISH2.2 -f /usr/local/grass5/etc/nviz2.2/scripts/nviz2.2_script el=f28elv2 -name NVIZ >&@stdout"
("eval" body line 1)
invoked from within
"eval exec $env(GISBASE)/etc/nviz2.2/NVWISH2.2 -f $env(GISBASE)/etc/nviz2.2/scripts/nviz2.2_script $argv -name NVIZ >&@stdout"
invoked from within
"if {$argv == ""} {
#no arguments
eval exec $env(GISBASE)/etc/nviz2.2/NVWISH2.2 -f $env(GISBASE)/etc/nviz2.2/scripts/nviz2.2_script -name NVIZ >&@stdo..."
(file "/usr/local/grass5/bin/nviz" line 16)
thanks inadvance
Ahmet Temiz
______________________________________
Scanned and protected by Inflex
http://pldaniels.com/inflex
The views and opinions expressed in this e-mail message are the sender's own
and do not necessarily represent the views and the opinions of Earthquake Research Dept.
of General Directorate of Disaster Affairs.
Bu e-postadaki fikir ve gorusler gonderenin sahsina ait olup, yasal olarak T.C.
B.I.B. Afet Isleri Gn.Mud. Deprem Arastirma Dairesi'ni baglayici nitelikte degildir.
