I’m having a problem accessing the PERMANENT folder in ‘bash’ (Grass 6.0cvs, cygwin setup.exe version 2.457.2.2). When i set up the location and mapset in bash and then press i get the following error:
Sorry, no access to <>
Mapsets in location
PERMANENT User1
Note: you do not have access to any of these mapsets
I’m not sure what is causing this
Whatever you Wanadoo
This email has been checked for most known viruses - find out more here
