I wish to promote and Introduce GRASS to Students of Engineering Collge.
So looking for good presentation on GRASS. Please let me know any good
source for that.
For the same objective, I tried following data sets.
SPEARFISH for GRASS 5.7
It appers to be working fine, but there is script in this data which may
show full potential od GRASS and this data set.
Fire simulation data set
There appears to be good script. But on GRASS-Beta2, it gave
"segmentation fault".
./firedemo.sh: line 22: 1398 Segmentation fault
See below signature detail of "log".
I am using it on Debian. Is there problem with GRASS-Beta2 or with
dataset?
Can you suggest any other good dataset or how to remove this
"segmanttation fault"? Or other link to good promotional material.
H.S.Rai
using default visual which is TrueColor
ncolors: 16777216
Graphics driver [x0] started
Prepare for simulation:
REMOVE [my_ros.max]
raster
header
category
color MISSING
history
misc
fcell MISSING
g3dcell MISSING
REMOVE [my_ros.base]
raster
header
category
color MISSING
history
misc
fcell MISSING
g3dcell MISSING
REMOVE [my_ros.maxdir]
raster
header
category
color MISSING
history
misc
fcell MISSING
g3dcell MISSING
REMOVE [my_ros.spotdist]
raster
header
category
color MISSING
history
misc
fcell MISSING
g3dcell MISSING
REMOVE [my_spread]
raster MISSING
header MISSING
category MISSING
color MISSING
history MISSING
misc MISSING
fcell MISSING
g3dcell MISSING
REMOVE [my_spread.x]
raster MISSING
header MISSING
category MISSING
color MISSING
history MISSING
misc MISSING
fcell MISSING
g3dcell MISSING
REMOVE [my_spread.y]
raster MISSING
header MISSING
category MISSING
color MISSING
history MISSING
misc MISSING
fcell MISSING
g3dcell MISSING
REMOVE [my_path]
raster MISSING
header MISSING
category MISSING
color MISSING
history MISSING
misc MISSING
fcell MISSING
g3dcell MISSING
Calculate the ROS (rate of spread), etc.:
Percent Completed ... 100%
Spread:
100%
./firedemo.sh: line 22: 1398 Segmentation fault r.spread -ds
max=my_ros.max base=my_ros.base dir=my_ros.maxdir
spot_dist=my_ros.spotdist
w_speed=wind_speed f_mois=1hour_moisture start=fire_origin lag=95
backdrop=image_burned output=my_spread x_output=my_spread.x
y_output=my_spread.y
Spread done.
Find some fire paths:
Thanks for your interest!
Sorry, <nsites> is not a valid parameter
ERROR: Required parameter <n> not set:
(The number of points to allocate).
Description:
Creates a raster map layer and vector point map containing randomly
located
sites.
Usage:
r.random [-qzi] input=name n=number[%] [raster_output=name]
[vector_output=name]
Flags:
-q Run quietly
-z Generate sites for category zero also
-i Report information about input raster and exit
Parameters:
input Name of existing raster map
n The number of points to allocate
raster_output Name of the output raster map
vector_output Name of the output vector points map
ERROR: my_spread.y - not found
100%
ERROR: Raster map [my_path] not available
