I'm sorry for being such a pain sending this question both to the winGRASS and the GRASS users list. I promise to improve in the future : )
Well, I'm trying to import sea surface temperature data obtained in the HDF-format from NOAA using grass6.0.cvs/cygwin running on Windows XP, but the following message appear:
ERROR 4: `198501h09ma-gdm.hdf' not recognised as a supported dataset name.
I’ve been through quite a few internet pages this weekend, searching for some way to get around this problem, but I’ve been unsuccessful so far : ( Is there anybody out there who knows how I could get around this problem
Thanks in advance,
Torkild
have a look at http://www.gdal.org/frmt_hdf4.html.
Use gdalinfo to list all multidimensional subdatasets from
the input HDF file.
Then choose the subdateset, which you'd like to import. You
should provide exactly the contents of the line marked
SUBDATASET_n_NAME to GDAL, including the HDF4_SDS: prefix
as
raster file to be imported.
like this:
HDF4_SDS:MODIS_L1B:GSUB1.A2001124.0855.003.200219309451.hdf:2
Hope this will help you,
Grit
On Sun, 13 Mar 2005 11:53:21 +0100
problem
Thanks in advance,
Torkild
Look at the r.in.aster script for a way to use gdalwarp within a grass
environment to read ASTER HDF files into GRASS and georeference them.
Something along the lines of what I did in this script should be relevant to
the NOAA data too.
Michael
____________________
C. Michael Barton, Professor of Anthropology
PO Box 872402
Arizona State University
Tempe, AZ 85287-2402
USA
Phone: 480-965-6262
Fax: 480-965-7671
Date: Sun, 13 Mar 2005 11:53:21 +0100
To: <grasslist@baylor.edu>
Subject: [GRASSLIST:6142] r.in.gdal and HDF import
I¹ve been through quite a few internet pages this weekend, searching for some
way to get around this problem, but I¹ve been unsuccessful so far : ( Is there
Thanks in advance,
Torkild
