Greetings,
When I attempt to run
$ grass5 -tcltk
the response is
WARNING: The wish command (/home/gjs/ActiveTcl/bin/wish) was not found!
Please check your GRASS_WISH environment variable.
When I check the GRASS_WISH environment variable with
GRASS: ~> g.gisenv GRASS_WISH
the response is
which seems okay. Furthermore when I copy and execute that string at a
bash prompt, the wish widget appears.
I'm a new GRASS user and am hoping to soon be a source contributor. Any
suggestions on how I should get the -tcltk option working? It appears
to me that the wish and tclsh binaries are installed correctly and the
GRASS_WISH and GRASS_TCLSH environment variables are defined correctly.
Maybe the "Please check your GRASS_WISH environment variable" suggestion
is a red herring?
Greg
$ grass5 -tcltk
the response is
Note: GRASS_WISH is an actual environment variable, not a GRASS
variable (unfortunately, some of the GRASS documentation confuses the
two).
the response is
is a red herring?
GRASS_WISH is treated as the base name of the wish program (e.g.
"wish" or "wish8.3"); the startup script looks for that file in each
directory in your current path.
Adding /home/gjs/ActiveTcl/bin to PATH and undefining GRASS_WISH (or
setting it to "wish") should work.
It should probably be changed to allow GRASS_WISH to be a full
pathname.
Glynn Clements wrote:
> $ grass5 -tcltk
> the response is
two).
> the response is
> is a red herring?
pathname.
Thanks. When I removed the full pathname definition of GRASS_WISH, the
-tcltk option worked.
It seems that GRASS_WISH is an over specification ... given the grass5
man page suggests using the PATH environment variable to define the path
to wish and suggests using a symbolic link to handle variants of the
wish filename.
Thanks again,
Greg
