Hello all,
I'm with a little problem, I need to convert the result of d.shademap (in
wich a hidraulic gradient is shown over a shaded relief dem, the same result
I can get with d.his leaving the Saturation empty and using hidraulic
gradient as Hue and shaded relief as intensity) into a new raster layer. I
tried r.his, but it's not working since it asks for existing raster maps for
R,G,B, and I want to create them!
thanks in advance
Carlos Henrique Grohmann de Carvalho - Guano
Geologist - MSc Student at IGc-USP - Brazil
Linux User #89721 PGP key: www.keyserver.net
Oops; thanks for the bug report.
If you have source code, it's simple enough to fix (details available
upon request).
Otherwise, if you create dummy maps with the desired names, and use
the "-o" switch, r.his will overwrite them (it's only the code which
checks the arguments which expects the maps to exist).
