[GRASSLIST:6172] Roor opening terminal: xterm
on 12 March I wrote:
I get an error whem I attempt to open a text shell (using $ grass5 - text) of
attempt to set a mask I get the rror ...
sh: line 1 : clear : command not found
Error opening terminal: xterm
I am running grass5.0.0 installed from a mandrake RPM under Mandrake 9.
I got several responses - mostly regarding links. However the soluton rested
with upgrading to Mandrake 9.1. The upgarde also solves a error in "R" which
says the terminal is not funtioning properly when "help" is queried.
many thanks
