I solved it but don't know what the problem was.
Command line editing did work and I had installed R
using a mandrake rmp (mandrake is very much like Red
Hat). But I just compiled the new R version 1.7 and
also installed the GRASS extension v 0.2-8 and now
command line editing does not work but at least when I
quit R from inside grass the terminal works ok.
Thanks for the attention
Daniel
> > > Hi all,
> > > Recentlly I started using R inside Grass but a
> > small
> > > problem is occuring. When I quit R, my
terminal
> > won't
> > > show the keys I type. Everithing works fine
but
> > > whatever I type is not shown. I'm usin grass
> > 5.0.2, R
> > > 1.6.1 and GRASS PKG 0.1-11
> > Could you say which platform and OS you are
using?
> > Does command line
> > editing work in R? Which shell do you use? R is
most
> > likely using
> > readline, and your shell may too.
> I'm using mandrake linux and bash shell. If by
command
> line editing you mean the up arrow to repeat the
last
> command then it's a yes or else I'm afraid I don't
> know what that is
>OK. Do the arrow keys sideways move you backwards
and forwards in the
command line? When you have retrieved a previous
command line, can you
change it (type into it after having gone to the
left end with the Home
key? Something seems to be happening when you leave
R to make the terminal
window go "insane", sometimes typingstty sane
helps, it resets the way the keyboard input is
displayed on the terminal.Does the same thing happen if you just run R by
itself without GRASS, i.e.
leaving R makes the terminal unusable? How did you
install R (rpm? compile
from source?)?I don't have access to Mandrake, but we can carry on
looking for things.Roger
> Thanks
> Daniel
> > > Thanks
> > > Daniel
> > Roger Bivand
> > Economic Geography Section, Department of
Economics,
> > Norwegian School of
> > Economics and Business Administration,
Breiviksveien
> > 40, N-5045 Bergen,
> > Norway. voice: +47 55 95 93 55; fax +47 55 95 93
93
> > e-mail: Roger.Bivand@nhh.no
> __________________________________
> Do you Yahoo!?
> The New Yahoo! Search - Faster. Easier. Bingo.
> http://search.yahoo.com
Roger Bivand
Economic Geography Section, Department of Economics,
Norwegian School of
Economics and Business Administration, Breiviksveien
40, N-5045 Bergen,
Norway. voice: +47 55 95 93 55; fax +47 55 95 93 93
Do you Yahoo!?
