Ok Markus, ok Glynn
Grass 5.0.2 has been just released, hasn't been?
I'm about to re-download the Grass (Xserver)!
In fact, 'usr\local\grass' might be damaged!
I'm gonna let you know my results
Thank you very much
José Anderson
---------- Mensagem original -----------
De : owner-GRASSLIST@baylor.edu
Para : Markus Neteler <neteler@itc.it>
Cc : grasslist@baylor.edu
Data : Fri, 9 May 2003 12:15:44 +0100
Assunto : [GRASSLIST:6234] Re: gisdbase errorMarkus Neteler wrote:
> - graphical startup doesn't work -> bug in Init.sh?
> - cmd line startup with path to GISDBASE doesn't work -
bug in Init.sh?Odd. At first I thought that it might be due to the use of
bash-specific features (Cygwin's /bin/sh is ash) but, apart from an
unrelated bug, it works with ash on Linux.The unrelated bug is:
trap "echo 'User break!' ; exit" 2 3 9 15
Signal 9 is SIGKILL, which can't be caught. bash seems to ignore thi
s,
but it causes total failure under ash (attempting to run external
programs fails).Can you provide more details regarding the failures? You can get
debugging information by using "sh -x ...", i.e.GISBASE=/usr/local/grass5
export GISBASE
sh -
x /usr/local/grass5/etc/Init.sh /path/to/gisdbase/location/mapset
