Hi all, I am trying to import some MASTER data (combined MODIS and
ASTER) that is an hdf4 file (it should have the same exact format as
MODIS data). After realizing that I need to import the subdatasets
(which import fine into an XY location), I have run into a problem. It
seems that the data I want is in one subdataset, but the latitudes and
longitudes are in separate subdatasets. How can I import this so that
the data I want is actually georeferenced?
I tried gdal_translate on a whim (gdal_translate -of GTiff -b 1
subdataset myfile.tif), but I ended up with a geotiff that either gives
me an error of "cellhd.proj = 0 (unreferenced)" or if r.in.gdal -o
"G_set_window(): Illegal latitude for South".
Anyone run into this before?
Ian
PS Using Mac 10.3.8, Grass 6.1cvs (march 22)
Ian MacMillan
Geological Sciences-UCSB
"insert witticism here"
On Fri, 25 Mar 2005 14:14:58 -0800
I've not imported hdf4 directly, but used the MODIS reprojection tool to tile and convert the data GeoTiff. Then importing it into GRASS was a breeze.
T
Trevor Wiens
twiens@interbaun.com
The significant problems that we face cannot be solved at the same
level of thinking we were at when we created them.
(Albert Einstein)
Ian
What does gdalinfo say about your hdf4 file? I've had an issue that hdf4 "Aster relative DEM" was not recongnized as georeferenced in newer Gdal
versions due to changes in the hdf driver. Maybe that is your case too?
Maciek
----- Original Message ----- From: "Ian W. Macmillan" <ian_macmillan@umail.ucsb.edu>
To: <grasslist@baylor.edu>
Sent: Friday, March 25, 2005 11:14 PM
Subject: [GRASSLIST:6258] hdf and modis/aster
Ian
Ian MacMillan
Here is the full output of gdalinfo. Bit long, but I think it looks normal (I don't have a ton of experience with these files yet).
GRASS 6.1.cvs (SonoraLL):~ > gdalinfo MASTERL1b_9900302_26_19990429_2141_2144_V01.1.hdf
Driver: HDF4/Hierarchical Data Format Release 4
Size is 512, 512
Coordinate System is `'
Metadata:
title=MODIS/ASTER Airborne Simulator (MASTER) Level-1B Data
ExperimentName=Baja Mexico
FlightDate=29 April 1999
FlightNumber=99-003-02
GeographicArea=Tres Virgenes, Line 17
ClockUsedToProcess=GPS Clock
DataSliceNumber=17
FlightLineNumber=26
TotalFlightLines=40
Credits=Gumley & Hubanks/design, Fitzgerald & Cleven/modify, maintain
MASDataUsersGuideSource=MAS World Wide Web site at http://ltpwww.gsfc.nasa.gov/MAS/Home.html
VIS/NIRCountSensitivityAdjustment=No
DataVersion=Version 1.0
SoftwareVersion=Version 9.0
CalibrationVersion=Baja_4/16-5/26 ver 0.1
data_set= MASTER Baja Mexico
data_product=straight-line flight tracks
geog_flag=c
day_night_flag=d
granule_version=1
metadata_version=9a
producer_granule_id=Version 1.0 Baja_4/16-5/26 ver 0.1
data_quality=Excellent
granule_size=3.986607e+08
begin_date=19990429 214107
end_date=19990429 214403
lat_LL=27.49829
lon_LL=-112.6536
lat_UL=27.49786
lon_UL=-112.809
lat_UR=27.53468
lon_UR=-112.8115
lat_LR=27.53519
lon_LR=-112.6534
Principle_Investigator=Joann Stock (Caltech)
Other_Aircraft_Sensors=RC-30
CreationDate=24-Aug-99 00:16:00
Subdatasets:
SUBDATASET_1_NAME=HDF4_SDS:UNKNOWN:"MASTERL1b_9900302_26_19990429_2141_2144_V01.1.hdf":17
SUBDATASET_1_DESC=[4378x50] BlackBody1Temperature (16-bit integer)
SUBDATASET_2_NAME=HDF4_SDS:UNKNOWN:"MASTERL1b_9900302_26_19990429_2141_2144_V01.1.hdf":18
SUBDATASET_2_DESC=[4378x50] BlackBody2Temperature (16-bit integer)
SUBDATASET_3_NAME=HDF4_SDS:UNKNOWN:"MASTERL1b_9900302_26_19990429_2141_2144_V01.1.hdf":19
SUBDATASET_3_DESC=[4378x50] AnalogGain (16-bit integer)
SUBDATASET_4_NAME=HDF4_SDS:UNKNOWN:"MASTERL1b_9900302_26_19990429_2141_2144_V01.1.hdf":20
SUBDATASET_4_DESC=[4378x50] AnalogOffset (16-bit integer)
SUBDATASET_5_NAME=HDF4_SDS:UNKNOWN:"MASTERL1b_9900302_26_19990429_2141_2144_V01.1.hdf":21
SUBDATASET_5_DESC=[4378x50] BlackBody1Counts (16-bit integer)
SUBDATASET_6_NAME=HDF4_SDS:UNKNOWN:"MASTERL1b_9900302_26_19990429_2141_2144_V01.1.hdf":22
SUBDATASET_6_DESC=[4378x50] BlackBody2Counts (16-bit integer)
SUBDATASET_7_NAME=HDF4_SDS:UNKNOWN:"MASTERL1b_9900302_26_19990429_2141_2144_V01.1.hdf":23
SUBDATASET_7_DESC=[4378x50] Head1Counts (16-bit integer)
SUBDATASET_8_NAME=HDF4_SDS:UNKNOWN:"MASTERL1b_9900302_26_19990429_2141_2144_V01.1.hdf":24
SUBDATASET_8_DESC=[4378x50] Head2Counts (16-bit integer)
SUBDATASET_9_NAME=HDF4_SDS:UNKNOWN:"MASTERL1b_9900302_26_19990429_2141_2144_V01.1.hdf":25
SUBDATASET_9_DESC=[4378x50] Therm1Temperatures (16-bit integer)
SUBDATASET_10_NAME=HDF4_SDS:UNKNOWN:"MASTERL1b_9900302_26_19990429_2141_2144_V01.1.hdf":26
SUBDATASET_10_DESC=[4378x50] Therm2Temperatures (16-bit integer)
SUBDATASET_11_NAME=HDF4_SDS:UNKNOWN:"MASTERL1b_9900302_26_19990429_2141_2144_V01.1.hdf":27
SUBDATASET_11_DESC=[4378x50] Therm3Temperatures (16-bit integer)
SUBDATASET_12_NAME=HDF4_SDS:UNKNOWN:"MASTERL1b_9900302_26_19990429_2141_2144_V01.1.hdf":28
SUBDATASET_12_DESC=[4378x50] Therm4Temperatures (16-bit integer)
SUBDATASET_13_NAME=HDF4_SDS:UNKNOWN:"MASTERL1b_9900302_26_19990429_2141_2144_V01.1.hdf":29
SUBDATASET_13_DESC=[4378x50] CalibrationSlope (32-bit floating-point)
SUBDATASET_14_NAME=HDF4_SDS:UNKNOWN:"MASTERL1b_9900302_26_19990429_2141_2144_V01.1.hdf":30
SUBDATASET_14_DESC=[4378x50] CalibrationIntercept (32-bit floating-point)
SUBDATASET_15_NAME=HDF4_SDS:UNKNOWN:"MASTERL1b_9900302_26_19990429_2141_2144_V01.1.hdf":31
SUBDATASET_15_DESC=[4378x716] PixelLatitude (32-bit floating-point)
SUBDATASET_16_NAME=HDF4_SDS:UNKNOWN:"MASTERL1b_9900302_26_19990429_2141_2144_V01.1.hdf":32
SUBDATASET_16_DESC=[4378x716] PixelLongitude (32-bit floating-point)
SUBDATASET_17_NAME=HDF4_SDS:UNKNOWN:"MASTERL1b_9900302_26_19990429_2141_2144_V01.1.hdf":33
SUBDATASET_17_DESC=[4378x716] SensorZenithAngle (32-bit floating-point)
SUBDATASET_18_NAME=HDF4_SDS:UNKNOWN:"MASTERL1b_9900302_26_19990429_2141_2144_V01.1.hdf":34
SUBDATASET_18_DESC=[4378x716] SensorAzimuthAngle (32-bit floating-point)
SUBDATASET_19_NAME=HDF4_SDS:UNKNOWN:"MASTERL1b_9900302_26_19990429_2141_2144_V01.1.hdf":35
SUBDATASET_19_DESC=[4378x716] SolarZenithAngle (32-bit floating-point)
SUBDATASET_20_NAME=HDF4_SDS:UNKNOWN:"MASTERL1b_9900302_26_19990429_2141_2144_V01.1.hdf":36
SUBDATASET_20_DESC=[4378x716] SolarAzimuthAngle (32-bit floating-point)
SUBDATASET_21_NAME=HDF4_SDS:UNKNOWN:"MASTERL1b_9900302_26_19990429_2141_2144_V01.1.hdf":43
SUBDATASET_21_DESC=[4378x50x716] CalibratedData (16-bit integer)
Corner Coordinates:
Upper Left ( 0.0, 0.0)
Lower Left ( 0.0, 512.0)
Upper Right ( 512.0, 0.0)
Lower Right ( 512.0, 512.0)
Center ( 256.0, 256.0)
On Mar 26, 2005, at 3:24 AM, Maciek Sieczka wrote:
Ian
Maciek
Ian
Ian MacMillan
Ian
Anybody correct me if I'm wrong, but it seems that gdalinfo doesn't recognize any info about the georefercing in your hdf - see "Coordinate System is `'".
This is likely the reason of your problems. Either your file is not georeferenced or there is something wrong with the hdf driver in gdal. Dig the gdal mailing list and bugtracker for relevant info and consider bugging gdal developers if needed then.
Maciek
----- Original Message ----- From: "Ian MacMillan" <ian_macmillan@umail.ucsb.edu>
To: "Maciek Sieczka" <werchowyna@epf.pl>
Cc: "GRASS Users Mailing List" <grasslist@baylor.edu>
Sent: Monday, March 28, 2005 4:39 PM
Subject: Re: [GRASSLIST:6258] hdf and modis/aster
Size is 512, 512
Metadata:
DataSliceNumber=17
FlightLineNumber=26
TotalFlightLines=40
geog_flag=c
day_night_flag=d
granule_version=1
metadata_version=9a
lat_LL=27.49829
lon_LL=-112.6536
lat_UL=27.49786
lon_UL=-112.809
lat_UR=27.53468
lon_UR=-112.8115
lat_LR=27.53519
lon_LR=-112.6534
Subdatasets:
floating-point)
floating-point)
Corner Coordinates:
Ian
Maciek
Ian
Ian MacMillan
According to the gdal maintainer (a few months back), there are problems
with the GCP and related data in Modis hdf files. So you can't use gdalwarp
to georeference them. The georeferenceing data in Terra ASTER hdf files is
OK. My r.in.aster script will georeference and import these data.
Michael
____________________
C. Michael Barton, Professor of Anthropology
PO Box 872402
Arizona State University
Tempe, AZ 85287-2402
USA
Phone: 480-965-6262
Fax: 480-965-7671
Date: Mon, 28 Mar 2005 06:39:19 -0800
To: Maciek Sieczka <werchowyna@epf.pl>
Cc: GRASS Users Mailing List <grasslist@baylor.edu>
Subject: [GRASSLIST:6269] Re: hdf and modis/aster
Size is 512, 512
Metadata:
DataSliceNumber=17
FlightLineNumber=26
TotalFlightLines=40
geog_flag=c
day_night_flag=d
granule_version=1
metadata_version=9a
lat_LL=27.49829
lon_LL=-112.6536
lat_UL=27.49786
lon_UL=-112.809
lat_UR=27.53468
lon_UR=-112.8115
lat_LR=27.53519
lon_LR=-112.6534
Subdatasets:
floating-point)
floating-point)
floating-point)
floating-point)
Corner Coordinates:
Ian
newer Gdal
Maciek
gives
Ian
Ian MacMillan
OK.
Right. Fortunatelly they are taking care of this:
To: <gdal-dev@xserve.flids.com>
Sent: Monday, March 28, 2005 8:51 PM
Subject: Re: [Gdal-dev] no georef in Aster relative DEM
Full support for HDF-EOS Swath products will be available soon.
Maciek
