[GRASSLIST:6270] v.in.ogr error
What is implied by the error:
GRASS 6.0.0 (arrowhead_utm):~ > v.in.ogr -o dsn=/Users/kirkw/projects/wrf/grids/ layer=forties output=forties
Over-riding projection check.
Proceeding with import...
Layer: forties
DBMI-DBF driver error:
Column 'PLS_FORTYP' already exists (duplicate name)
Cannot create table.
Error in db_execute_immediate()
ERROR: Cannot create table: create table forties_grid (cat integer, AREA
        double precision, PERIMETER double precision, PLS_FORTYP integer,
        PLS_FORTYP integer, COUN integer, TOWN integer, RDIR integer, RANG
        integer, SECT integer, FORT integer, GLOT integer, PARC integer,
        FORT_DESC varchar ( 40 ), GLOTMATCH integer, GEOPARC integer,
        GEOGLOT integer, GEOFORT integer, GEOSECT integer, GEORANG integer,
        HECTARES double precision)
I am trying to import some shape files into utm location in grass6.0. The shape files have the naming scheme:
forties.dbf
forties.sbn
forties.sbx
forties.shp
forties.shx
Kirk
Layer: forties
RANG
integer,
The problem is that your dbf file contains two columns with exactly the same
name (PLS_FORTYP) which is unacceptable for the database driver. Change one of
the column names in the table before using v.in.ogr or use the cnames option
of v.in.ogr.
Moritz
forties.dbf
forties.sbn
forties.sbx
forties.shp
forties.shx
Kirk
Thank you Moritz. I just stumbled to the fact that the help documents on the web (http://grass.itc.it/grass60/manuals/html60_user/v.in.ogr.html) are more detailed (including additional information concerning v.in.ogr options) than those that are generated from the build and install process. I will look on the web in the future.
Kirk
Layer: forties
RANG
integer,
of v.in.ogr.
Moritz
forties.dbf
forties.sbn
forties.sbx
forties.shp
forties.shx
Kirk
on the web
This is weird. I have exactly the same manual page locally as the one on the
web. Maybe there was some error building the docs on your machine ?
Moritz
Kirk
Layer: forties
AREA
integer,
RANG
integer,
integer,
the same
Change one of
option
of v.in.ogr.
Moritz
forties.dbf
forties.sbn
forties.sbx
forties.shp
forties.shx
Kirk
on the web
If there was, there is nothing in the error.log
Moritz
Kirk
Layer: forties
AREA
integer,
RANG
integer,
integer,
the same
Change one of
option
of v.in.ogr.
Moritz
forties.dbf
forties.sbn
forties.sbx
forties.shp
forties.shx
Kirk
> one on the web. Maybe there was some error building the docs on your
> machine ?
Look for "modules without description.html" towards the end of the build
process, not in error.log. Or cd vector/v.in.ogr/ and type "make" to
rerun the man page building for that module. e.g. it has been
demonstrated recently that running 'make -j 3' on a multi-processor
computer causes some of the help pages to not build properly.
The website version of a help page will in many cases be more up to date
than the release versions, as the website version is updated from the
latest CVS at least once a week. Looking at the v.in.ogr help page
though, there have been no changes since 6.0.0 was released:
http://freegis.org/cgi-bin/viewcvs.cgi/grass6/vector/v.in.ogr/description.html
Hamish
