Hi All,
Well, I started using my .DXF tiles from the Irish Ordinance Survey. The
new computer is (Dual Processor G4) is doing the v.support with out a
problem. (It's a lot faster than my G3 Powerbook).
A question. I want to colourize the contour areas, i.e. Have the lower
elevations in green, middle elevations in yellow, and mountainous regions in
brown. How would I go about doing this. The contour layers were set up in
10s (10, 30, 70, etc.), 20s (20, 40, 60, 80, 120, etc.) and 50s (50, 100,
150, etc.). I also have spot heights, and the text labels.
BTW, is it common for contour layers to be set up in this way?
Also, I was going to use NVIZ to create 3d maps. Should I also run
v.in.dxf3d or v.in.dxf3d.sh? For future reference, can I just use
v.in.dxf3d.sh when I want to create both 2d and 3d maps?
Thanks for any help.
Kurt Springs
