Dear GRASSLIST-member,
I compiled GRASS 6.0 + selected Libs on SUSE 7.3 from source. There were no severe problems encountered - besides gdal. From version 1.2.2 on (including 1.2.2) compilation on gclib < version 2.3 is not possible. So I had to use the gdal version 1.2.1. I used this in combination with gdal-grass-1.2.3. GRASS 6.0 starts and I can import and work with spearfish.
But when I try to import srtm-data I fail.
The import runs without error. But when I display the result, there is just a white monitor.
I run the same site using GRASS 6.0 on cygwin without any problems.
OK, Suse 7.3 is old-fashioned and I can use GRASS 6.0 on cygwin. It is just the first time, that I encountered a backward incompatability on Linux and I cannot believe there is no workaround.
Any idea?
Thanks in advance.
Karl Broich
Dr.-Ing. Karl BROICH Tel: +49 / (0) 89 / 6004 2478
Universität der Bundeswehr München Fax: +49 / (0) 89 / 6004 3858
Institut für Wasserwesen
Werner-Heisenberg-Weg 39
D 85577 Neubiberg
