Dylan,
On Tue, Mar 14, 2006 at 10:04:52AM -0800, Dylan Beaudette wrote:
Markus,
Nice images!
a couple things:
1. the link at the top of the page had some interesting polar plots.
For hard copy I found that ps.rose in the GMT suite produces excellent
results as well:
http://169.237.35.250/~dylan/NPS/day100.png
yes, there is also some R extension for that.
I just thought to have it directly in GRASS (6.1-CVS).
Someone may change the xgraph output to d.graph for consistency,
cannot be hard (hey, maybe you?).
2. the color boost technique -- is your script available on the GRASS
wiki somewhere, or in the grass scripts dir in a recent CVS branch?
Sure...
This looks like it will do the trick, now the only problem is that I
have just put together the entire state of Arizona with the poor
looking imagery!
Sorry - I had written the script three weeks ago but didn't advertise it
yet.
I have added parser support today, get it now from
http://mpa.itc.it/markus/grass61/demos/
-> i.landsat.rgb
6.1-CVS is needed as it uses a new feature of r.univar.sh.
thanks for the tips,
cheers
Dylan
> >Hi everyone,
> >I was working on constructing some "true color" landsat composite images today
> >from bands 3,2,1 -- and came across some strange inconsistencies. Data from
> >one source produces "nice" true color images:
> >http://casoilresource.lawr.ucdavis.edu/drupal/node/211
> >whereas, another source produces somewhat muddy true color composites. I tried
> >playing a bit with an equalized grey colormap for each band via r.colors
> >color=grey.eq with the following results:
> >http://casoilresource.lawr.ucdavis.edu/drupal/node/215
> >Does anyone have any tips on how to tweak color ramps for the various bands so
> >as to get a better looking "true color" composite?
> how do you like this LANDSAT:
> -> LANDSAT 7 color boost
> Markus
Markus Neteler <neteler itc it> http://mpa.itc.it
ITC-irst - Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18 - 38050 Povo (Trento), Italy
