I installed everything about grass in debian
apt-cache search "grass" gives:
gpx2shp - convert GPS or GPX file to ESRI Shape file
grass - Geographic Resources Analysis Support System
grass-doc - Geographic Resources Analysis Support System documentation
libgrass - GRASS GIS development libraries
libgrass-dev - GRASS GIS library development files
/usr/local/bin/gdal-config --formats # contains grass:
gxf gtiff hfa aigrid aaigrid ceos ceos2 iso8211 xpm sdts raw dted mem
jdem envisat elas fit vrt usgsdem l1b nitf bmp pcidsk airsar rs2 ilwis
bsb gif jpeg png "grass"
but:
ldd libgdal.so.1.6.0 does not contain anyword like grass
where is libgdal1-grass package ?
I was not able to find it ?
apt-cache search "libgdal1*"
libgdal1 - Geospatial Data Abstraction Library
libgdal-doc - Documentation for the Geospatial Data Abstraction Library
libgdal1-dev - Geospatial Data Abstraction Library - Development files
On Sal, 2005-04-12 at 16:00 +1200, Hamish wrote:
> in debian I installed
> libgdal1_1.2.5-1_i386.deb
> libgrass_6.0.0-1_i386.deb
> but ldd /usr/lib/libgdal.so.1.6.0 does not anything
> about grass
> what is the problem ?
oh, if you are using Debian it is easy, you just need to install the
GRASS plugin for GDAL: the libgdal1-grass package.
libgdal1-grass - GRASS extension for the Geospatial Data Abstraction
Library
This provides /usr/lib/gdal_GRASS.so
GRASS works fine with this installed.
If you install the qgis-plugin-grass package, that should get you most
of the things you need I think.
Debian's mapserver package is brand new, it should make it into
the Testing archive very soon (maybe today/tomorrow?). see:
http://packages.debian.org/cgi-bin/search_packages.pl?exact=0&searchon=names&version=all&case=insensitive&release=all&keywords=mapserver&arch=any
See the DebianGIS pages, they are doing great things:
http://pkg-grass.alioth.debian.org/cgi-bin/wiki.pl
Hamish
______________________________________
XamimeLT - installed on mailserver for domain @deprem.gov.tr
Queries to: postmaster@deprem.gov.tr
The views and opinions expressed in this e-mail message are the sender's own
and do not necessarily represent the views and the opinions of Earthquake Research Dept.
of General Directorate of Disaster Affairs.
Bu e-postadaki fikir ve gorusler gonderenin sahsina ait olup, yasal olarak T.C.
B.I.B. Afet Isleri Gn.Mud. Deprem Arastirma Dairesi'ni baglayici nitelikte degildir.
