Hi all.
Does anybody know whether it is possible to work (import-export) with 3D
shapefiles, with gass or other free software?
Thanks.
pc
Paolo Cavallini
cavallini@faunalia.it www.faunalia.it www.faunalia.com
Piazza Garibaldi 5 - 56025 Pontedera (PI), Italy Tel: (+39)348-3801953
I made such experience, that GRASS is able to import 3D shapefiles and other
formats via OGR.
Any software, which uses OGR should do that. See
http://www.gdal.org/ogr/drv_shapefile.html
Jachym
On Wed, Apr 13, 2005 at 09:00:52AM +0200, Paolo Cavallini wrote:
Hi all.
Thanks.
pc
Paolo Cavallini
Jachym Cepicky
e-mail: jachym.cepicky@centrum.cz
URL: http://les-ejk.cz
GPG: http://www.fle.czu.cz/~jachym/gnupg_public_key/
Hi all.
Funny - I tried the same yesterday.
Generally yes for GRASS 6:
Note: import into any location (e.g., Spearfish sample location)
################ 3D DXF/DWG example
#Example: 3D DXF from http://www.3dcafe.com/asp/architex.asp#DXF
v.in.dwg -z in=dxf/WATRTOWR.DXF out=watertower
v.info watertower
| Map is 3D: 1
| N: 584.584 S: -599.734
| E: 579.789 W: -584.248
| B: -1873.830 T: 594.000
# -> unprojected DXF (use v.transform to geocode it)
g.region vect=watertower res=10 -pa
#take B (bottom) as minimum elevation:
r.mapcalc "plane=-1873.830"
r.colors plane col=gyr
#look at it:
nviz plane vect=watertower
#Result, something like this:
# http://mpa.itc.it/markus/grass60/nviz_watertower3D.png
3D SHAPE: If PolygonZ is properly used it should
work as well (v.in.ogr). Currently I don't have
and true 3D SHAPE file to try.
Best
