I installed everything about grass in debian
apt-cache search "grass" gives:
gpx2shp - convert GPS or GPX file to ESRI Shape file
grass - Geographic Resources Analysis Support System
grass-doc - Geographic Resources Analysis Support System documentation
libgrass - GRASS GIS development libraries
libgrass-dev - GRASS GIS library development files
apt-cache search "libgdal1*"
libgdal1 - Geospatial Data Abstraction Library
libgdal-doc - Documentation for the Geospatial Data Abstraction Library
libgdal1-dev - Geospatial Data Abstraction Library - Development files
You need to add the DebianGIS repository (use the unstable branch).
Stuff is slowly filtering into the main Debian repository from there, but
works pretty well. Some of the java-dependent software (jump) is in
contrib until it can be made with the free java clones.
> See the DebianGIS pages, they are doing great things:
> http://pkg-grass.alioth.debian.org/cgi-bin/wiki.pl
then:
$ apt-cache search grass
libgrass0 - GRASS GIS development libraries
libgrass0-dev - GRASS GIS library development files
libgdal1-grass - GRASS extension for the Geospatial Data Abstraction Library
qgis-plugin-grass - Plugin for accessing GRASS vectors from QGIS
$ apt-cache search gdal
gdal-bin - Geospatial Data Abstraction Library - Utility programs
python-gdal - Python bindings to the Geospatial Data Abstraction Library
DebianGIS package lists:
[i386]
main:
libjama-java
libpostgis1-pg74
libpostgis-doc
libpostgisjava
grass
libgrass0
libgrass0-dev
grass-doc
libjts-java-doc
libjts-java
libgdal1-grass
qgis-plugin-grass
qgis
qgis-dev
mapserver-doc
perl-mapscript
mapserver-bin
cgi-mapserver
libmapserver-dev
python-mapscript
php4-mapscript
contrib:
jump-postgis-plugin
bsh2-doc
bsh2
jump
http://pkg-grass.alioth.debian.org/debian-gis/dists/unstable/main/binary-i386/Packages
http://pkg-grass.alioth.debian.org/debian-gis/dists/unstable/contrib/binary-i386/Packages
[source]
main:
jama
postgis
grass
jts
libgdal-grass
qgis
mapserver
contrib:
postgisdriver-jump
bsh2
jump
http://pkg-grass.alioth.debian.org/debian-gis/dists/unstable/main/source/Sources
http://pkg-grass.alioth.debian.org/debian-gis/dists/unstable/contrib/source/Sources
it all works!
Hamish
