Hi Jaime and the rest of the list,
Just to say that I'm now one of the topmodel developers at Lancaster. We are doing a major cleanup of the code and intend to release some new versions soon, although in R rather than in GRASS (for several reasons...) incorporating Monte Carlo and other stuff.
BTW, there is a bug in the r.topmodel infiltration module which Huidae Cho fixed some weeks ago but probably didn't make it to the official version yet.
Anyway, if you have more questions about topmodel, feel free to ask via the list or directly to me.
cheers
wouter
On Thu, 30 Mar 2006, Thomas Adams wrote:
Jaime,
I believe I can help you, although:
(1) I have never run TOPMODEL in GRASS (just the Fortran standalone version)
(2) the link to Lancaster Univ. is old, in fact I'm not sure Kieth Bevan
Lancaster Univ. even make the original source available now, from what I can
see at: http://www.es.lancs.ac.uk/hfdg/freeware/hfdg_freeware_top.htmMy guesses are these, since they conform to the GRASS r.topmodel manual page
and the original files for the standalone version of TOPMODEL:parameters=3Dstring
(i) TOPMODEL Parameters file, where the standalone file looked like this:SUBCATCHMENT 1
0.032 5.0 50. 3600.0 3600.0 0.05 0.0000328 0.002 0 1.0 0.02 0.1I can not remember what's what; I'll have to dig this up, plus I'll have to
look at the r.topmodel source code more =97 I believe the data are read in this
order from what I can see in the source=85input=3Dstring
(i) Rainfall and potential evapotranspiration data file {probably a space
delimited file with 2 columns}
output=3Dstring
(o) Output file {looks like flow is cu meters/timestep}
Qobs=3Dstring
(i) OPTIONAL Observed flow file {single column file}My recollection is that the inputs are in terms of meters/time-step (flow
would be cu. meters/delta-t) =97 but I MUST CONFIRM THIS!The original input file in the standalone version combined the GRASS input
Qobs files and looked like this:950 1.0 <=3D=3D=3D=3D=3D=3D Number of timesteps & Number of hours per time step (I
believe)
.0000000 .0000619 .0000328
.0000000 .0000647 .0000325
.0010000 .0000619 .0000330
.0010000 .0000560 .0000333
.0010000 .0000457 .0000348
.0005000 .0000323 .0000356
.0005000 .0000156 .0000356
.0000000 .0000000 .0000356
.0005000 .0000000 .0000351Notice that the values are very small, which makes me believe that I think my
guess about the units of the input are correct; this could be different in
the GRASS r.topmodel code, of course. The columns are, respectively,
precipitation, PE, and ObsQ.At least this can get you going. I'll try to get more on this in the
next few
days. With a little help of some of the more experienced GRASS module=20
contributors, I don't mind taking this on.Regards,
TomJaime Carrera wrote:
Has any one used the r.topmodel module? If so, I have the following
questions:
1) What are the instructions that are required in the "topmodel paramet=
ers
file"?
2) How should the topographic index statistics file be written?Cheers,
Jaime
