[GRASSLIST:6468] ps.map output resolution
I was searching for, if possible, a way to increase ps.map output resolution.
Do someone knows if this is possible (and how)?
Thanks, Michele.
____________________________________________________________
6X velocizzare la tua navigazione a 56k? 6X Web Accelerator di Libero!
Scaricalo su INTERNET GRATIS 6X http://www.libero.it
resolution. Do someone knows if this is possible (and how)?
Do you mean for raster maps? It just uses the region's resolution:
g.region res=
Otherwise everything is scaled at 72dpi, but as PostScript is vector
based, making it 300dpi wouldn't cause any change.
Hamish
PostScript files don't have a resolution.
When rendered directly to screen or on a printer, they will be
rendered at the device's resolution.
If you convert them to raster images (with e.g. GIMP or ImageMagick),
they will be rendered at a specific resolution. The resolution is
normally user-configurable, although the default is often quite low
(typically 75dpi). How to specify the resolution depends upon the
program.
