[GRASSLIST:6470] r.terraflow weirdness
I'm getting a "stats.out: Permission denied" error with r.terraflow, but the
output directory is clearly owned by me (I've changed it to a number of
different directories). Any ideas? I was able to run this a few days ago,
I don't know what's changed...
--j
Jonathan A. Greenberg, PhD
NRC Research Associate
NASA Ames Research Center
MS 242-4
Moffett Field, CA 94035-1000
650-604-5896
AIM: jgrn307
MSN: jgrn307@hotmail.com
but the output directory is clearly owned by me (I've changed it to a
number of different directories). Any ideas? I was able to run this
a few days ago, I don't know what's changed...
what about setting the STREAM_DIR= option? maybe you don't have
permissions in the /var/local dir for the temp files?
(using /var/local is a known bug, it should use $MAPSET/.tmp/$HOST/)
Hamish
