Hi
Is it normal and intended that "0" is taken the same as the "null" when doing "r.mapcalc 'MASK=some_raster"? It took me over an hour to guess my there where holes in my MASK. Shouldn't "0" be treated as a regular, valid value for MASK?
Maciek
Hi
Maciek
Yes.
Masks used to be zero/non-zero before support for a distinguished NULL
value was added in 5.0. The existing behaviour maintains backwards
compatibility.
doing "r.mapcalc 'MASK=some_raster"?Yes.
Shouldn't "0" be treated as a regular, valid value for MASK?Masks used to be zero/non-zero before support for a distinguished NULL
compatibility.
I see. But is backward compatibility so important here? IMHO all Grass oldtimers users got used to using NULL for no-data instead of ZERO, and newbies use NULL by default.
Also, all Grass commands I know use NULL for no-data. And if they support ZERO it is an option. Shouldn't MASK follow this?
Just my ideas.
Thanks
Maciek
> Yes.
> NULL value was added in 5.0. The existing behaviour maintains
> backwards compatibility.I see. But is backward compatibility so important here? IMHO all Grass
It's a true/false thing. 0 is false.
It could be better documented, but where?
A lot of the old raster modules still only have minimal floating point
support, let alone NULL support..
nope. Where would you put the option? g.gisenv? I think it would lead to
many disasters.
Hamish
