Hi Martin
Just run dos2unix on that file and that will do it.
Jaime
--- Martin du Saire <mdusaire@umn.edu> wrote:
I ran the following command in Cygwin/Grass60:
v.in.ascii input=vectordata output=myvector
where vectordata was:
230092.881535|2417442.264625|Name
This generated a WARNING: Dos text format found,...
It appears that it correctly generated the vector,
but is the "Dos text
format..." going to be a problem a some point?Thanks.
M
_________________________________________________________
Do You Yahoo!?
Información de Estados Unidos y América Latina, en Yahoo! Noticias.
Visítanos en http://noticias.espanol.yahoo.com
