[GRASSLIST:6568] ASCII to grid
Hello,
i`m trying to import a grass created rasterfile (r.out.gdal)into ArcView 8.3
over the Toolbox. But i get always this error:
An error occurred while running Ascii to Grid. Unloading the Tools.
Does anybody has an idea what's going wrong here?
thanks
Stefan Gasser
Stefan
8.3
r.out.gdal can output a dozen of formats
which one did you use?
For transferring a Grass raster into ArcInfo I use the r.out.arc. Although Gdal is in general also capable of writing ARC ASCII GRID it has
problems with floating point data in this case, depending on the amount of no-data value in the beginning of you raster.
Maciek
thanks
Stefan Gasser
