hello
I try to compile mapserver with grass support. But nothing seems to contain "grass".
I follow the instructions in http://grass.itc.it/start.html
after compiling mapserver
/var/www/cgi-bin/mapserv -v gives:
OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER INPUT=EPPL7 INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
grass is plugin gdal.
gdal_GRASS.so has been created.
/usr/local/bin/gdal-config --formats
gxf gtiff hfa aigrid aaigrid ceos ceos2 iso8211 xpm sdts raw dted mem jdem envisat elas fit vrt usgsdem l1b nitf bmp pcidsk airsar rs2 ilwis bsb gif jpeg png
nm /usr/local/lib/libgdal.so.1.7.0 | grep "GRASS"
gives nothing
why is grass missing ?
is grass being unseen in gdal normal when grass is plug in gdal ?
regards
______________________________________
XamimeLT - installed on mailserver for domain @deprem.gov.tr
Queries to: postmaster@deprem.gov.tr
The views and opinions expressed in this e-mail message are the sender's own
and do not necessarily represent the views and the opinions of Earthquake Research Dept.
of General Directorate of Disaster Affairs.
Bu e-postadaki fikir ve gorusler gonderenin sahsina ait olup, yasal olarak T.C.
B.I.B. Afet Isleri Gn.Mud. Deprem Arastirma Dairesi'ni baglayici nitelikte degildir.
